Auf deutsch weiter unten
Hello everyone,
I am experiencing a persistent problem with my Nuki Opener connected to a Ritto 4630/00 TwinBus intercom system. I would appreciate any advice from users with the same intercom system or from the Nuki team. The support does not answer to my mails…
Setup
- Intercom: Ritto 4630/00 TwinBus
- Nuki device: Nuki Opener
- Firmware: 1.12.4
Problem description
The Opener worked perfectly for approximately one month. Without any changes to the installation or wiring, the doorbell detection suddenly became unreliable.
When the problem occurs:
- The normal indoor intercom bell still rings every time someone presses the doorbell.
- The Nuki Opener does not register the doorbell event. No corresponding event appears in the Nuki event log.
- Consequently, Ring to Open does not work either.
- Manual door opening via the Nuki app continues to work reliably.
I have also noticed that when Ring to Open is enabled, the Opener’s LED flashes at regular intervals. When someone rings the doorbell, the flashing briefly stops and then resumes. However, the door does not open, and no doorbell event is recorded in the event log.
Temporary workaround
If I disconnect the cable between the Opener and the intercom system and reconnect it, doorbell detection starts working again immediately. Ring to Open also works as expected, but just one time. After that I have to reconnect it again.
Troubleshooting already performed
- The wiring has not been changed.
- New opener
- A factory reset has also been performed, but the problem persists.
- Manual door opening via the app works even when doorbell detection has failed.
- The normal indoor doorbell continues to work during the failure.
Any suggestions or information from Nuki or other users with a Ritto 4630/00 would be greatly appreciated. I’m just confused because it worked perfectly for a month.
Thank you!
Hallo zusammen,
ich habe ein anhaltendes Problem mit meinem Nuki Opener in Verbindung mit einer Ritto 4630/00 TwinBus-Gegensprechanlage. Vielleicht hat jemand mit derselben Gegensprechanlage ähnliche Erfahrungen gemacht oder kann mir bei der Fehlersuche helfen, da mit der Nuki Support leider nicht antwortet…
Meine Konfiguration
- Gegensprechanlage: Ritto 4630/00 TwinBus
- Gerät: Nuki Opener
- Firmware: 1.12.4
Fehlerbeschreibung
Der Opener hat ungefähr einen Monat lang problemlos funktioniert. Ohne dass ich etwas an der Installation oder Verkabelung verändert habe, funktioniert die Klingelerkennung plötzlich nicht mehr zuverlässig.
Wenn der Fehler auftritt, zeigt sich folgendes Verhalten:
- Die normale Wohnungsklingel funktioniert weiterhin bei jedem Klingeln an der Haustür.
- Der Nuki Opener erkennt das Klingeln jedoch nicht. Im Nuki-Ereignisprotokoll wird kein Klingelereignis aufgezeichnet.
- Dadurch funktioniert auch „Ring to Open“ nicht mehr.
- Das manuelle Öffnen der Haustür über die Nuki-App funktioniert weiterhin zuverlässig.
Zusätzlich ist mir Folgendes aufgefallen: Wenn „Ring to Open“ aktiviert ist, blinkt die LED am Opener in regelmäßigen Abständen. Sobald jemand an der Haustür klingelt, wird das Blinken kurz unterbrochen und setzt anschließend wieder ein. Die Tür öffnet sich jedoch nicht, und im Ereignisprotokoll erscheint kein Klingelereignis.
Vorübergehende Lösung
Wenn ich das Verbindungskabel zwischen dem Opener und der Gegensprechanlage abziehe und anschließend wieder anschließe, funktioniert die Klingelerkennung sofort wieder. Auch „Ring to Open“ funktioniert danach wie vorgesehen, allerdings nur 1x, bis ich wieder das Verbindungskabel neu anschließe.
Bereits durchgeführte Maßnahmen
- Die Verkabelung wurde nicht verändert.
- Opener Austauschgerät mit gleichem Verhalten.
- Ein Werkreset wurde ebenfalls durchgeführt, jedoch ohne dauerhaften Erfolg.
- Das manuelle Öffnen über die Nuki-App funktioniert auch dann, wenn die Klingelerkennung ausgefallen ist.
- Die normale Wohnungsklingel funktioniert während des Fehlers weiterhin zuverlässig.
Ich würde mich über Hinweise vom Nuki-Team oder von anderen Nutzern mit einer Ritto 4630/00 sehr freuen.
Mich verwundert einfach, dass es einen Monat lang wunderbar funktioniert hat.
Vielen Dank!
