Request to enable webhook.central scope
Hello, I have been granted access to the Nuki Advanced API and can see the OAuth2 API Secret. However, I do not see the webhook configuration options in the “Nuki Advanced API Integration” tab. My use case requires receiving real-time lock/unlock events to validate time-based access sessions in my application. Could you please enable webhook support (webhook.central scope) for my integration? Thank you.
Hi Hugo,
Welcome to the forum :wave:
Can you confirm which “Type” of Advanced API you have? You can see this within the “Nuki Advanced API Integration” tab. If you applied for “Only OAuth 2 API Secret”, then you will not have access to webhooks. If this is the case, you will need to delete and re-apply for the Advanced API once more.
Hey Andrew,
Yes I confirm that it’s Only OAuth 2 API Secret type.
I would follow your advice to delete and re-apply but I already have some dependencies on the tokens created.
That would disrupt my current implementation.
I would be very grateful if there is another way to do it without disrupting what I have implemented.
If not, how long would take to have the new application validated?
Thank you for your reply.
Cheers,
Hugo Pereira
