We’re finding opening our lock (Nuki 3.0 Pro) quite slow when using either Apple Watch or iPhone, sometimes up to 10 seconds waiting for the device to connect and the lock to respond/open. Auto unlock on the other hand works great, but we often don’t go far enough away from home to cause auto unlock to become active. So I’m looking at alternatives that might improve this.
I’ve seen the announcement re: Keypad 2.0. My hesitation is that it still connects via bluetooth to the lock, so I assume isn’t likely to be that much faster than using Watch or iPhone. True? Or has Nuki done some clever engineering to ensure it connects and opens more quickly?
(A random thought) Is it possible to ‘force’ Nuki into Auto Unlock mode without exiting the geofence area? Or could we manually reduce the geofence area to cause it to trigger when we move away from our property by a smaller distance?
I just installed my Keypad 2.0 and you are correct, it connects directly to the lock via BT.
From putting your finger on the lock until the lock starts turning I would say it takes around 3 secs on average.
Mine I think it’s defective by keyboard or by print or it doesn’t open me or it takes 30 seconds to 1 minute and more than 10 times only 1 opens it already sent me open and used.
I got it changed with this one but I got in bad shape for the transport, I came in an envelope and the crushed batteries chapita.
I could get them right and the batteries made contact, but you can see that it’s broken.
If I open the door with minimum 30s keyboard or don’t open.
I have Facebook since it came out but I don’t like it the only network I use are Telegram and twitter groups.
It’s great!
I would have advised another option I have seen the inside and where it makes the hole with the file may have echoed a thread with a male 3mm or less but 3mm enter.
And screw two screws one on each side so it blocks it equally and more secure.
