Opener FW Update - misleading description
Hi all,
I am getting this FW update description for my Opener:
Der Opener muss neu konfiguriert werden (Administration > Opener konfigurieren) damit die Änderungen wirksam werden!
Ein funktionierendes Nuki Opener Setup sollte nicht neu konfiguriert werden.
I feel this message is contradicting as it says a re-configuration is required but also not advised at the same time. Is it safe for me to update the Opener or not? I have a setup for a ‘Generic / analogue’ intercom that is not officially supported and it works fine. Installed FW is still 1.1.10.
Thanks and regards
Thomas
Seems like a poorly worded response. I guess what they wanted to say is: If you update to the latest firmware (which is recommended) nothing will change with your setup unless you reconfigure the Opener.
Hi Jürgen,
Thanks for the clarification. I updated the Opener without the need of a re-configuration and all still works fine.
Thanks and regards
Thomas
