Nuki universal cylinder - key doesnt slide well in
Yesterday i installed my universal cylinder for nuki ultra. Unfortunately the key doesnt slide well into the lock. I have to try it serveral Times until it slides in.
Anyone Else with that problem?
That the key goes a bit shaky into the lock is the same with almost all Nuki cylinders when they’re new. It gets better with time. But you can also spray some ballistol into the opening, it should be easier. Be careful, it has to be resin-free oil, otherwise the cylinder will stick over time.
