Hi Jürgen,
Thank you for the reply.
After further review, I think at this stage we are simply going to connect the Front Gate + Front Door + Internal Switch in order to keep remove a lot of the complexities (Although it already seems very complex).
I have tried to go ahead and create a wiring diagram for the electrician as they have never installed Nuki before and have requested it, but with the lack of clear documentation I am stuck. Could you please indicate how the following should be wired for this to work? Once it is wired up, do they need to configure the devices using the App?
Do you have any suggestions on the relay to use? Is there a way to do this with an all in one device rather than an exposed circuitboard?
Thanks a lot!
