Nuki Pro 3.0 make a http call when opening? To switch on outside lights via relay
Hi there,
we’re using a Nuki for the door at our house; does the Nuki Pro (so no bridge needed) send anything via network when an unlock action is performed? I’d like to keep it as simple as possible, ideally when unlocked it would just call something like http://192.168.xxx.xxx/relay/1?turn=on to turn on our lights outside via a Shelly 1.
I assume that would also be possible via MQTT, but then I’d need another device acting as a broker.
Or via Google Home, but then I need an active internet connection - which I have, but keeping it simple and local would be a plus.
Of course that would also work with an opener I guess, which features a simple relais? But is a bit expensive just for that use case.
Thanks!
No, the only local option is to do this via MQTT.
