Nuki calibration with doors with a bottom latch
Hallo!
I have a door which also has a latch on the bottom, which means that during the calibration process, the lock can’t rotate to a fully locked position because it advises to maintain the door open (while the door is opened the latch is misplaced and can’t enter on a hole in the ground). Is there any way to solve this problem? Maybe a manual calibration process?
Thank you
Calibrate with the door closed and push it slightly so that it remains in closed position while the Smart Lock pulls the latch.
Danke Jurgen! It worked!
