MQTT error every 6 minutes
I have my locker connected to Home Assistant, via a Mosquitto MQTT broker, working in good conditions. However, every 6 minutes, the MQTT Broker gets “false” on the topic nuki/AAAAAAA/connected and, 7 seconds later, receives a “true”. This fact shows, in Home Assistant, the locker is unavailable many times over the day. Can you please help me troubleshooting this anoying error?
Looks like a connectivity problem and the Smart Lock loosing WIFI connection regularly. You could try to connect it via Thread or use the WIFI compatibility mode.
After changing to Wifi compatibility mode the recurrent errors stopped. Not lets see the battery consumption.
The ideal would be to swap to thread but so far was not able to have a stable network
Thanks for your help
