I have built my own presence detection system around my Nuki 3 Lock, Home assistant and a few ESP32. Everything is working consistently, except for the lock itself.
Its responsive (less then 1 sec latency) about 60% if the time, the remaining ones it takes 5+ seconds for the lock to react.
Since I know the lock has to perform an unlatch action 1-5 min before it takes place, is there a way to warm up / prepare the lock and the bridge to reduce latency? Maybe by preventing it from sleeping or by reducing the polling time between the lock and the bridge?
The lock is already set to “Fast” in the settings panel.
Would restarting the bridge, say every night speed up the connection? Or maybe every time the lock has to be used?
- Nuki Lock 3
- HACS Nuki plugin Home assistant
- Lock version 3.4.9
- Bridge version 2.14.0
- No errors in Home assistant while unlatching the lock
- Lock RSSI -51 dBa
- Bridge RSSI -61 dBa
- Bridge callbacks are on
- Lock battery 73%
