I need some help with connecting the opener with the Golmar T-5822vd. It only has two wires in the Bus insert. See photo. Does anyone know how to connect this?
Many thanks!
Many thanks!
I tried to use the genereic (bus) setup. But in the last step it asks to ring the bell and to confirm that it has rung, but then I get a screen that I have to use an alternative setup. But then I come in an infinite loop where I need to do the same setup all over again.
Did you ever get it figured out?? If so, please post pics!!
I got it to work! Thanks to help from JungleDev and a description by Nuki Support.
Apparently this is how to set up the Golmar T-5822VD (bus) for the Nuki Opener:
Your current setup might vary:
In both setups, all you need to do is connect two wires from the Nuki Opener to the left side BUS connections in the intercom.
(See picture)
Then when setting up choose the intercom Brand and Type select Generic (Bus).
Follow the instructions and you’re all set!
Please mind:
Hi guys, I am looking into the same intercom and I am a bit stuck.
I connected Black/Red to the left bus. This are all cables I have connected, nothing on HZ like the yellow/green Patrick has in the pictures.
Might this be the issue?
I solved that puzzle, my intercom is wired incorrectly.
So I changed the nuki cables red to left, and black to right. This solved my issue of not getting a signal.
Hope this will help someone!
