The most devices running mini servers can be update via serial port, just like routers or IP cameras. As far as I know, the firmware version of this smart lock can also be updated/modified via USB TTL.
Is this firmware “modification” process deeper than the OTA (over the internet) update process? Does it overwrite all files and directories? Does it actually re-flash the memory of the device?
During a traditional update (OTA) process, is it possible that the software is only partially upgraded?
The first time (after paired the phone with the lock) I try to connect to the Internet, even if I enter the password correctly, it won’t connect. I have to go into the settings about wifi again to enter the password and then it connects. I have updated the system, I don’t know what wrong.
Is it possible that I need to completely “flash” or reinstall the system?
