Bridge api don't respond
Lately I got 2 new white Nuki Bridges, each paired with 1 Nuki Smart Lock. One works fine and responds to API requests, the other one shows the same error as explained in this thread. Both bridges are in the same LAN and both bridges are directly talked to by a python tool (that btw worked fine with my old gen. 1 bridge, too). For testing purposes I also sent an API request via a REST-Tool to both bridges - with the same result: one responds correctly, the other one shows either a request time out or error 405. I also tried a factory reset and new install - that didn’t change anything of the behavior. And this behavior is also independent from running the App (in the App, the Smart Lock with the Bridge thats behaving strange, is always 1-2 seconds delayed when showing the status). Firmware is the latest and the same on both bridges (and SmartLock). I don’t understand that, so please help. Thank you.
