Hi guys,
Do you know if is possible to open the door with auto unlock, not only to unlock it?
The option is automatically set based on your âdoor fittingâ setting.
And you can also override it to your liking in the Auto Unlock Expert settings (which, however, should be treated as such and not changed too lightly ).
Hi Stephan,
I can found any option to âopenâ the door in the fitting area, can you give me more details?
In the app go to something called âchoose doorlockâ. There you choose for âbar or knobâ instead of âdoorhandleâ. It is possible that in english it is called something else. Mine is in dutch. But i hope it helps you in the right direction.
