API does not respond on commands
Hello @Stephan,
after re-setting everything again and starting over and playing around with it half the night I figured that it has to be the fact, that the bridge is LAN-only.
Now with the newest beta-firmwares installed and reset, it works reliable since about 6 hours to call the API, when the bridge is connected to the internet. When it is LAN-only it stops working properly and gives me all the above headaches.
Could you please revisit the LAN-only behavior of the API and make sure the bridge can work reliable when not connected to the internet?
This is a bug in the Android App which is fixed in the newest beta (going live soon).
Thanks for the work you put into testing. I will further investigate on our side and put up some testing scenarios. We have several users with a local offline-setup, but there definitly seems to be a problem related to the bridge showing an IP of 0.0.0.0.
Thank you @Stephan,
please let me know when you have something ready for testing. I’ll be happy to try it out.
i know this is my third entry to this problem.
But i have exactly the same issue. I’m using the Software Android Bridge (my LAN is unifi too) …
it is not working without internet access.
Did you find any workaround for the issue? Without any hint for an upcloming patch, i. e. a sane solution I was thinking of rate limiting the packets to the nuki servers or to try to introduce a fake local one. The last idea wouldn’t work if the certificate is pinned.
Patrick
no, it took me the last night to figure out why the sw bridge wasnā€˜t responding.
today i finished my first version for knx but if this bug will stay iā€˜m going to remove the bridge solution.
cloud isnā€˜t a solution for me!
is that issue with not obtaining a local IP address properly finally solved and can the Bridge work LAN-only? I don’t want it to talk to the internet. I want my local server to talk to it and process all events. I have several bridges and locks in different places and I want to have them finally proper integrated in my ā€œhouse managementā€ solution, have rules triggered, etc. without that I need to give them access to the internet (which I don’t have in two places - yes, believe it or not, there’s houses that don’t have internet access and don’t need it :wink:).
