Alarming smartlock wobble
How much should the smartlock wobble when it is locking/unlocking the door? Mine was fairly steady to start with, but after a week or so it is beginning to move from side to side quite noticeably, although it doesn’t seem loose. (How do you get it off, by the way? It clicked into place with great finality, and I can’t see a way to release it.) I have a euro profile cylinder with a knob on the inside which has been replaced with the green adapter.
Hola, sacas las pilas y después miras y verás de color amarillo una pibote, solo tócalo un poco y la cerradura saldrá, después desmontas el soporte, un consejo revisa lo dirá que va tú cerradura al cerrar y pon un poco de aceite para engrasar debería mejorar.
Thank you, that worked perfectly. Turns out that the green adapter that replaced the internal knob was disintegrating. I’ll order another and try again.
